Discuss PIPE FREEZER in the Plumbing Tools area at PlumbersForums.net
Looking to get one of these for a while and just got a job that's perfect for it to save me a fat drain down on a very old property, which one do you guys who use them rate, this place has 28mm return so ideally something suitable for that. Cheers.
I was thinking about renting but not sure if they do that type of thing around me
Pipe Freezer 12-42Mm - 240V - HSS Hire - https://www.hss.com/hire/p/pipe-freezer-12-42mm-240v depending where in East Sussex, but a few branches available.
If you still want to purchase one, not sure if this any good? Rems Eskimo Set - Pipe Freezing Device - https://www.heatdirect.co.uk/rems-eskimo-set.html?gclid=Cj0KCQjwssyJBhDXARIsAK98ITSb4zH9jXjJFSjXctxkgtniK-1_nQb-be9870gZtrVO-neUp0Ex2oMaAjIREALw_wcB
Reply to PIPE FREEZER in the Plumbing Tools area at PlumbersForums.net
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
