peteisfishing
Hi all, quick one, is there any requirement to insulate Central Heating pipes in the attic if they are plastic??....going to anyway, just wondering if there is something written down somewhere
Discuss Plastic & Insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
By plastic do you mean Hep pipes? There is no need to lag this, complete waste of time...it is a barrier pipe...even better protected from the elements than copper with lagging on it
You don't lag a pipe to protect the pipe; You lag it to prevent the water inside the pipe for freezing.By plastic do you mean Hep pipes? There is no need to lag this, complete waste of time...it is a barrier pipe...even better protected from the elements than copper with lagging on it
Im talking about barrier pipe. I never use it unless i need to (awkward area under a floor etc) as I hate the stuff and i dont trust the fittings. I dont used push fit fittings when I do have to use it, I use compression but I certainly dont lag it.
I have seen hep pipe with compression fittings blow off in last winter pipe expands and fitting pop off not good
Barrier pipe lads...with 3 liners...you arent going to convince me
Reply to Plastic & Insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
