Discuss Plume redirection? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Robert Tyrrell
I've been to quote for a job of replacing an oil boiler but before I submit the final quote I'm just wondering about the flue.
It's a vertical flue going through a shallow roof void, exiting under the eaves for another part of the same building, and redirecting around the guttering by virtue of 2 x 45 bends.
This in itself isn't really a problem as I see it but the flue is definitely unstable in high winds and I wondered if, to reduce any problems whereby the flue might get blown off the vertical, I could use a plume redirection kit as the flue exits the roof tiles?
Something like the right hand one in this image that I've nicked from the Grant website. This might, just might, clear the guttering with enough clearance.
Reply to Plume redirection? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys I have an Ideal Logic System s24 which was installed approx 2 years, and haven't had any problems with it. This morning there was a wet...
17K
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in...
5K
  • Locked
I've got a customer whose boiler I serviced last year and they've asked me if there's anything that can be done about the poc from the boiler as...
1K
  • Locked
Hi, New member - in fact have joined specifically to ask this question! Is anyone aware of any regulation (planning, Building control or...
1K
abcgascare
A
