Discuss Potterton promax 30 HE PLUS issues. Wembley. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
phozy888
Hi Guys,
my boiler has started to switch itself off after a few minutes so I took the fron cover off to check the diagnostics lights. Its flashing like this : FLASH - OFF -ON.
Having read the manual it shows a overheating lockout - The manual shows 3 possible faults.
1 - The PCB
2 - Red Thermistor
3 - Thermo Stat
Which would be the likely cause ? I was just going to order and replace 2-3 as they parts are relatively cheap. Or could it be another issue ?
I'm in the Wembley area - Any Engineers that can give me a quote
Thanks !!
Thank you Phozy888.
please PM Phozy direct if you are interested in this job.
Reply to Potterton promax 30 HE PLUS issues. Wembley. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
  • Locked
My boiler Ideal Logic 30 Combi shows flame loss error (F2 fault). Boiler is in the newly property and so far has been used just for hot water...
4K
  • Locked
Hi, 10-12 year old Main 12 HE (similar/same to Baxi & Potterton) boiler feeding CH and indirect cylinder. Last night, gone midnight, prep for...
2K
Hello again all: Firstly: Personal background, as I know people are likely to ask: 1) I AM GSR 2) Most of my work so far since qualification has...
