Discuss PRD Pressure Relief Device for Triton Showers in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
A
Andrew hawkes
My builder has fitted 14 Triton Showers to a block of flats which I let out, they are manager by a letting agent, I am now getting complaints that the pressure relive valve is operating and the agent informs the Plummer who changes £80 to fit a new £5 pressure relive valve
HOW CAN I modify the heater to stop this? Andrew
Have you used the shower head and flex that came with the unit also I’ve had it before now someone was blocking the shower head
If there new there under warranty
Also don’t forget the agent puts there mark up ontop of the plumbers bill
If not the above then possibility that the cold water storage tank(s) is more than 10M higher than the shower resulting in excessive pump discharge pressure or somehow the shower supply is from the mains, this assumes a shower like the Triton T90SR which is a integrally pumped shower.
Reply to PRD Pressure Relief Device for Triton Showers in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Morning All I have a Megaflo unvented cylinder . Water had been dripping into the tundish so I tried to recharge the air gap, but when I went to...
Hi, The pressure release device in my Triton Aspirante shower has blown; unfortunately I can't work out how to access it to replace it It is...
2K
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Units involved: Gainsborough 10.5SE heater unit with Swirl (Screwfix 278PG) overhead shower kit with diverter. Hi guys. I have a Gainsborough...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
