Discuss Press fittings gas mechanical or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gingalig
Hi
I spoke to gas safe today as wanted clarification that it was or was not considered a mechanical fitting using press fittings on gas pipework, the response was that it was to new to call and i would need to speak to the manufacturere, long story short and a lot of call waitiing and i didnt get through , anyone had clarification on this ? aploogies for the spelling.
Same as soldered
So not mechanical
Think your onabout mechanical in regards to compression fittings eg removable and positioning
Yes fine where you can’t get access to
Yes treat the same as soldered
I asked GS too. Their reply:
Press end fittings should be installed following manufactures guidance, if none is available then guidance can be found in British Standard 6891:2015. Within in this standard it make multiply notes that press end fittings should not be buried underground, within walls or within floor screeds etc.
Reply to Press fittings gas mechanical or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
