Discuss Push fit soil pipes.. in the USA area at PlumbersForums.net
Does it matter if they aren’t fully inserted, as long as they go past sealing ring? I cut a bit of pipe 1-2cm too short and can’t get it out the other side to change!
should be fine aslong as theres no movement
As long as you de-burred the inside edge of the pipe you should be alright. If it's at all past the o-ring it shouldn't leak and if the pipe is deburred it shouldn't catch debris on the way through even if there is a small gap between pipe end and the stop inside the fitting.
Reply to Push fit soil pipes.. in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
