Discuss Question about Cold Water Booster Set in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Gents
I have problem with pressure in my house. Plumber advice my to read about cold water booster set, it is grate solution in that kind of situations i read. I think i will go for one of this device. My question is how do you sizing this to the property, what should i take into consideration. What is the best quality for money???
I’m going to a house where we fitted one. Will,try and film it to show how quiet they are.
Don’t know how to post a video on here tho.
when you do send it via my email will sort it
There is an alternative. Just call the manufacturers and ask their advice. I have never yet been let down by a manus advice re pumping. All ask extensive questions to make sure you get what is appropriate.
What mains pressure and flow rate are you currently getting?
pressure maybe 1 - 1.5bar but i will have to checked, flow rate no idea is it meter?
have dedicated space kind of utility/plant room but is not very much, not for 1000l or more this 500 looks grate and it will fits, but i am not sure if the efficiency will be right or might be to much and i will spend lots of money needlessly
How is your hot water heated??
system boiler and cylinder
eye watering ...pun...price...I would want to know much more about the property before making any advice just yet
centralheatking
What you need to know?
So you need at least 300 so around 400 I would recommend
plenty but busy till later m6 stuffed again chking
on website which you gave me, they have 375 or 490 both with 3bar.
is it means i will get 3 bar whole house?
Correct
as well in option for 0.8, 1.5 or 2.6 l/sec
is it mean 0.8x60= 48l/min so 100l bath will fill up in 2 minutes??
Aslong as your pipe sizing is correct yes/ you could
purely theoretically what size of pipes should i have?
Don’t have a clue would need to work it out length fittings etc best get an experience plumber in
ok , before I would specify anything on this job I would want to know
1. heating system full details
2. present water pressure & volume per. min...and customer expectation
3. building lifestyle ..how many people..is it domestic or commercial
4. future plans extensions etc
5. customers intended budget to makecsure we are all singing off thevsame hymm sheet.
then I would produce a specification get it approved, put a fixed price quotation in at proper commercial rates draw a contract up, take a deposit and deliver it in specified timescale
subject to variations
however if the op puts up the info properly we can all have a proper look in my opinion
Rob Foster. aka centralheatking
If you have a good pressure but poor flow, supply partially blocked, leaking or undersized. What size is the Property??? Is it on Gravity System? Tanks in loft & Cylinder???
I agree ...loads of questions before any advice ..no shooting from the hip in my operation....except on saturdays
centralheatking
Hi Rob,
1. I don't know probably full details of heating system but i can tell you there is 12 radiators (4towell rails) , boiler Vaillant 30kw, 4 zones (1 underfloor heating) but i don't know why you ask about the heating if i need suite only pressure and flow rate???
2. 1.5 bar, volume i don't know? But i read 18l/min is descent
3. 2+2 family + 2 parents/visitors. It is my house.
4. no more kids:) no extensions. Just sort this house nicely
5. budget i don't know i would like to buy something right quality to money and install my self. I know how to hold spanners and pliers.
There is basement, ground, 1st and loft. Unvented Sealed system. Pipes size i think is OK 28mm mainly. Friendly plumber advise me to boost everything and that's why i look for help and advice
Hi Rob,
I luv these sort of threads over a weekend ;)
Can you guys design something for me from little or no intel, I don`t know the budget but I want to install it myself cos I know how to hold spanners and pliars.
:D:D:D:D:D:D:D:D
:D:D:D:D:D:D:D:D
Sorry if you gays feel used, but i really try save some money, anyway i will install something i just don't want learn on my mistake because it will cost me a lot 3-4k if i don't get right result. I am DIY person, know how to solder on my own purposes, some knowledge i have i like to know what's going on in my house, ect. If you don't want to help its OK i will be just little bit sad because i was thinking this is forum for everyone not only pro
It is for everyone but what you are trying to install is certainly not a diy install. It’s going to take correct sizing, planning and installation to get a system that you’re happy with. Please don’t take offence
Sneaky, sneaky Mateus, seeing how the letters U and A are so far apart on the keyboard that can not be labelled a mistake so you can take a running jump!
Hey Riley, do you honestly think it can be done via the internet when the op gives intel in the manner he does?
No offance at all, i know is hard that's why i am here if will be easy it will be done already, is a lot to consider and now i realize even more that, and if i take plumber not enough experienced a don't have warranty as well. hmm goddam life
Shoun in your opinion what size of pipe should go to 2 floor to get that time of filling bath??
At a guess no calcs 28 or 35mm with swept bends but this might be on the large size
Good bit of kit, but So expensive though! Couldn’t you just get a cold water accumulator?
I fitted a Stuart Turner ‘Mains Boost’ a few months back. I phoned Stuart Turner and with a few simple measurements and questions they were able to specify the correct product. Very helpful company and great quality products.
http://www.stuart-turner.co.uk/products/mainsboost/
you could if pressure was higher if i remember hes only got 1.8 bar
i would want a min of 2.5 bar dynamic for a accumulator
Mainsboost offers a simple solution to boost low mains water pressure without the need for a break tank and is designed to be connected directly to the incoming mains.
Dan is it tanks with the pump or just a tank( something like vessel in my system). Can you explain more about it.
On website says ,,Designed for unvented systems where the mains pressure is greater than 2.0 bar but water flow is inadequate''
that's what i don't have but if i conjunct Mainsboost pressure vessels with Mainsboost Charger Pumps i could install to my main water pipe and get higher pressure and flow rate, am i right?
Reply to Question about Cold Water Booster Set in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Hi, would be extremely grateful for any advice on the following. I'm installing a bathroom (shower, toilet and sink) in my summer house. It has...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
