Discuss Rad Valve/TRV sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plum Bob 66
Hi
Just been to price up a job to excahnge 5 trvs like for like. The valves look to be a larger size than regular. Can you more experienced boys out there give a heads up on the different sizes.The connecting nuts to the tails look bigger than usual and im guessing they are 10 to 15 years old.
Regards
Plum Bob:confused:
It will be half inch tails with 3/4 nuts. Just change the tails too.
Reply to Rad Valve/TRV sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rad is leaking from TRV valve, seems to be seeping out of where the pin comes up. I tried tightening up the nut below the pin, but that didn't...
I have Honeywell Valencia TRVs 10mm pipe size, I’m making mods to accommodate larger rads and it looks like the 10mm compression insert is special...
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
Hi All, I thought I'd come to the experts and see if anyone is installing and/or recommending the use of any Smart TRV valves? Particularly in...
2K
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
