Discuss Re positioning 15mm solderd joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to swing out a 90 15mm copper fitting to fit a new radiator valve (marked 1 in photo).
Can I apply heat to the 90 degree joint to loosen the solder and pull the 15mm pipe
to the correct position so the valve fits the rad?
You can certainly sweat the joint apart yes
You will find for best results,clean around joint with wire wool,add flux and then heat and move,then add a little more solder to outer fitting
I would recommend you drain the system to below that level and then sweat it off carefully without disturbing the tee below it with too much heat.
Then clean the copper pipe end with emery cloth & steel wool or similar (often find fittings not soldered fully & pipe has dirty patches) & use a brand new fitting.
Reply to Re positioning 15mm solderd joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Does adaptor exist? Hi, looking to move a rad, the original valves will be hidden behind a bath, so I was wanting to leave original valves in...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
1K
I am fitting a new shower valve, it has 1/2 inch compression female in/outlets. I am using a 1/2 in ch to 15mm elbow to get me into my copper...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
