Discuss Recent boiler room upgrade in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Timmy D
Subscribed
For those interested, here’s a recent install.
Heat loss reduced Timmy ?
Will be when finished lagging it all.
There’s also quite a loss on the DHW flow/return pipework through the house, which I can’t get to….
no I mean sorry remove 150kw of boilers and sticking maybe 60 kw back in etc ?
Wow @Timmy D Thanks for posting! What a transformation! It must feel satisfying finishing a job like that, How long did it take?
Reply to Recent boiler room upgrade in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
