Discuss Sabre boiler in kitchen cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I'm about to refit our kitchen, but have a pretty ugly Sabre 29 HE boiler in one corner. Am I able to build this into a kitchen cabinet?
The installation guidance gives a minimum clearance at the front of 600mm, but does this include a kitchen cabinet door?
Thanks in advance.
Mike
No it doesn't the given sizes are clear sizes so after them your fine
Hi
Thanks in advance.
Mike
If you are fitting a new kitchen do you have the budget to change the boiler at the same time?
Hi, sorry I'm probably being dumb, but I don't think I understand. Is it ok to put it in a kitchen cabinet?
Yes fine just make sure it can be removed when you decide to change the boiler
Harvest makes a good point , the last thing you want is to be changing the boiler after the kitchen is fitted , yes ok its fine now and hopefully will be for a few years to come , have you any idea how old it is , if its under 5 forget it , if its approaching 10 , I would seriously consider it . My opinion of course .
I agree i would seriously consider changing it you will achieve a better finish on your new kitchen as a modern boiler is alot smaller . cheers kop
Reply to Sabre boiler in kitchen cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
