Discuss Sealing Back to Wall Pan in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The Boss wants me to seal the sides and top of the pan against the WC cabinet. Obviously I will seal around the base but I think sides and top will look rubbish.
What do others think?
White silicon and just fill in any gaps etc
What is the largest gap size, see some that are way out from the cabinet panel and they do look carp when silicone is applied.
Never had one more than 5/8 mm that said. I have been told I have been lucky.
My gaps are pretty small but down the sides at least the ceramic curves in towards the WC cabinet so that my Fugi won't help.
However, I'd best give it a go for the sake of domestic harmony!
Thanks for the input.
Just use the 90 profile to fill in the ceramic curve
Silicon spray helps with anything if the tool grips too much
Will agree with above 5-8mm line will look need and acts as strengthener.
Just spray it wit soapy water then use whatever device u like to remove excess silicone...Lidl do some really good silicone tools...
Reply to Sealing Back to Wall Pan in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
