Discuss self tap in screws and flues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
how many of you put self tap in screws in all flues on new boiler installations
as far as i'm aware, vaillant are the only ones which come with the screws, but you still see so many ecotecs without the screws put in
Baxi and Worcester do too now. If it's in the mi then it needs screwing. I can't see anyone getting grief for screwing and clamping a flue either way tho.
i do gets screwed 6times per joint cost about 3 for 100
for all models and lengths
Sorry guys , viessmann DO NOT require screws , the boiler shaun has just posted is not a boiler i have seen , their domestic boiler is a WB 1 C , the 200 's dont need them either, if you dont believe me ring their technical on monday morning.
Fancy a pint now don't ya?!
they do that covers
vitodens 100-W WB1 Series,
citodens 200-W WB2 Series,
Vitodens 200-W B2HA/ B2HB Series and
Vitodens 222-F B2TA/ B2TB Series
(with preinstalled coaxial vent pipe adaptor
and another point gas safe will fail any installation of any flue without screws or support
Their flue elbows come with 2 small little holes where you can see if the flue is starting to come apart.
Personally I would prefer them to be screwed , but as I say ring em if you dont believe me .
fail enough
question from gas safe what stops them from coming apart theres no glue no fixings : nothing and they will right you up on it
Manufacturers rule ok lol
not gas safe and they will fail you on it and my mis state different
[DLMURL]http://www.viessmann.co.uk/content/dam/internet_uk/images/products/vertical_flue_installationmanual.PDF[/DLMURL]
Its an email from viessmann to one of their installers.
The only problem with expansion is over long lengths same as copper, and on anther point there's no internal expansion joint on the flue anyway eg no extra space once the flue in inserted to td (fully to stops) so it's going to expand over the length not internally
and what stops the flue expanding out of its socket like gutters on a warm day ;) eg working loose over time
Screw all mine, use self cutting screws from screwfix, literally a couple of seconds and its done
Easydrive Self-Drilling Low Profile Pan Head Screws 4.8 x 16mm Pk200 | Self Drilling Screws | NoLinkingToThis
Reply to self tap in screws and flues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve cleaned the grooves and tightened the grub screw at the bottom, but this tap handle (on the right of the photo) just won’t stay put. When...
Hi. I believe this boiler can be changed to a system or combi. Does this mean the hot and cold tails have to be blanked off?? Also the horizontal...
