Discuss Shower install advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
After some advice please.
Recently bought some shower panels to have installed. However the installers must have missed installing the waterproof trim I bought as didn't use it? How much of a problem is this?
I was told by another installer that it should be used as external seals are no where near as good and will just lead to problems down the line. Am I worriying about nothing or do I need to take the panels off to put the trim on.
TIA
I’m guessing here you mean the internal corners ?
If yes there rubbish and I agree don’t need / use them
Definitely not worrying about nothing. The waterproof trim is important to prevent water damage. I'd recommend getting it installed, as external seals might not be as effective. You might want to discuss this with the installers and see if it can be added without taking the panels off. Better safe than sorry.
Reply to Shower install advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was...
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
