Discuss Shower pressure terrible in 5 year old house with unvented system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
Inerz
Thanks for taking the time to read, and sorry if posted in wrong section wasn't sure if it was generic as includes both shower and heating system.
I've just purchased a property built in late 2010, 3 story's and the previous owner was a British Gas engineer so therefore had an unvented system installed professionally ( won't find a better system on the whole estate apparently) however the only problem is that the en suite shower, located on the same floor as the cylinder approx 5 metres away, is little more than a trickle, very difficult to wash under, was wondering what the problem could be as its a real nuisance, the stopcock under sink is fully open, what steps should I take? Should I measure the litres of water from each tap on each floor to check flow rate is there? Or is there something else a miss. I've attached 3 photos of the system. Thanks for any help.
if it is just one itenm with poor flow then it will be down to that. if all other taps are ok suggest you get someone to check the shower out,
Thankyou for the replies, turns out it was a flow restrictor in the shower head, removed it and hey presto can actually shower now
Reply to Shower pressure terrible in 5 year old house with unvented system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains pressure. I bought it hoping I could have two showers across floors running with hot water even if it’s a short while, while avoiding an unvented...
Max Hill
M
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better way to go. Just after some advice and rough costs involved, is it worth getting a pressurised system installed and a new boiler and oil pump? Heating...
What the easiest way to find why my boiler is losing pressure. It is about 5 years old Vaillant combi boiler, we have just had 2 vertical radiator removed and refitted for decorating and now the pressure keeps dropping approx once a week. I guess a leak under the floor is possible, or trapped...
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years old now and was amazing when it was first installed. Around a year ago we had a problem with water dripping from the overflow pipe outside and we ended...
