Discuss Shower tray drilling advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I need to find out if I can drill a larger hole in my shower tray, it’s size atm is 1 1/2 inches (38.9mm) and I want to make it 90mm to increase water removal flow
Is this possible
Yes...hole saw for plastic, diamond coated for stone. Ideally you'll need to reconstruct a false center for either bit to locate.
You may increase the size of the trap but if the waste pipe is the same diameter the water removal rate will much the same once the trap is full.
Are you sure it's the tray waste and not a blockage or restriction (too many elbows) in the waste pipe running away from the tray?
Would be a pity to fit a bigger drain in the tray only to find out it still runs slow.
What size it the pipe from the tray 32mm, 40mm or 50mm?
Hi thanks for your reply, I’ve removed the trap and it was clogged with sludge and hair
I’ve cleaned it and it’s a little better
My thinking was the bigger the trap the faster the water flow
The pipe is 40mm
Reply to Shower tray drilling advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I am trying to clean out my Merlyn Truestone slate shower tray waste unit. I cannot see anyway to remove it to clean underneath. I'm stuck...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and...
Hi all Plumber who fitted shower frame didnt put sealent behind frame to tray before fitting frame. Now leaks when water gets into frame and...
Hi all I have two hairline cracks around shower tray plug waste hole. Is this a concern ? I.e let water in etc through crack ? And any fixes...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
