Discuss single or double ended socket soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is it best to use a single or double ended socket when connecting on to an orange soil pipe to run an internal stack
If its going straight up I always try to glue a single socket 1st as low as poss,
Then push one of these into that and work from there :D
I'm not a fan of having pushfit double socket although it does work but I don't like the thought of it over time.
As above I always try to have a fitting right at ground level then work up from there
all depends on what is on the end of the soil pipe in the ground. socket or pipe :)
Reply to single or double ended socket soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
