Discuss Small header tank in loft and overflow in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
N
Neil e
Hi
I have noticed dripping from the overflow pipe coming from the header tank (smaller tank in loft) not sure why but I cannot adjust the ball value thing or how to. I have removed some water from the tank but there is a copper pipe which should sit in the tank but not where it feeds to
Any ideas?
Many thanks Neil
Most likely, the float valve needs its the washer and possibly cone that forms the seal replacing. Should also check the concentration of corrosion inhibitor in the heating system as it will have been diluted by the dripping.
I don't understand this part of your post:
"... but there is a copper pipe which should sit in the tank but not where it feeds to"
Hi thanks for your reply. Think I will change the float valve as I assume they are adjustable so you can let less water in. Hard to explain the Cooper pipe. Can you post picture on this forum?
Reply to Small header tank in loft and overflow in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
