Hi All,
Having the layout on the ground floor reworked, the plans to do so included moving the internal vertical soil pipe on the ground floor too.
This pipe picks up the bathroom and en-suite on the 1st floor, and bathroom on the top attic floor too. So quite a bit goes through it, though on our re-worked ground floor layout its ended up being in a very awkward place, causing a problem for our design, so it has to move.
The image below is the current soil pipe layout.
It's a problem for the 'new bathroom, its far too central in that room, so we'd planned to push it to the right (looking at the house from the rear)... ideally lining it up with the vertical stack that runs above it from the 1st floor to the top floor, and in the process, eliminating the horizontal kink between the 2 vertical sections altogether, as on the image below.
BUT, unfortunately when we removed the downstairs ceiling in the 'new bathroom' room, as shown on the picture above, we found an RSJ right beneath where the soil pipe begins to kink sideways. Scuppering our original plan to line it all up vertically, argh!
I'm looking at alternative options of how I can have this pipe reworked. Though im no plumber so wanted to get a read on how drastic/silly i'm being with the alternate options below (in an ideal world it would end up being as close to the 'original plan' idea as possible)
Do any of these look acceptable/appropriate?
Or if any of you have a better suggestion, i'd love to hear it. As I said, im not sure how the above will fare with blockages etc, i'm not experienced with this sort of stuff.
Here's a short video with commentary of inside the room if that helps at all. - Vimeo - https://vimeo.com/manage/videos/636823080
