Discuss solvent weld waste fittings/overflow fittings turned yellow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Thought these only turned a yellow tint when uv hit them?
Had some kept in a dark shed for a while in a plastic tub and they have started to turn yellow, especially the overflow fittings.
The white rainwater used to go pink in UV.
But don't worry, there is no additional charge for the colour-morphing fittings.
It may be time to finally fix that hole in the roof.....[emoji6]
Hehe, no hole In my roof! Fittings 4+ years old though!
ive had the same thing happen, you would expect it of abs in sun light as its an internal only pipe but in a dark shed :(
Its the amount of fire retardant in the plastic that turns it yellow after a few years.
Reply to solvent weld waste fittings/overflow fittings turned yellow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
