Discuss sooting in builders opening terminal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Burning damp coal
Generally tho, a lack of air produces excess smoke which produces soot.
A gas appliance should never produce smoke/soot if it is burning properly. Failing the flue flow test indicates a partial blockage or more air needed. Can also be effected by the terminal position and the weather.
Are you sure there has not been a solid fuel in before?
If it was a back boiler in before it will be a class 2 chimney (5")
May be a GC1 or similar on top.
What type of fire is fitted
Has the opening got a smooth tapered transition on to the flue liner?
Something like this required
Reply to sooting in builders opening terminal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
