Discuss Stub stack in disabled toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sheff paul
Is there any rules regarding stub stacks in disabled toilets,as need an air admittance valve as the run is long and it has to be boxed in in the corner of the disabled toilet, does the boxing contravene the Doc m requirments
as-long as the boxing is tight you will be fine seen loads tight and tiled ontop
Just done one with the stub stack to the left and behind as if you sat on the pan, no rails to go their so can't see a prob with it.
I usually make sure I leave an access panel on the top of the boxing incase any faults with the AAV in the future.
Reply to Stub stack in disabled toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
