Discuss Suggestions on how I should correctly seal this value in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What should be a straight forward connection is proving to be something annoyingly different.
I have a 1/2 inch compression coupler which I am attaching to a new shower mixer valve (cold inlet).
The photo doesn't show this but I have applied what I thought was adequate PTFE tape (10 rotations) and before screwing the coupler in I inserted a 1/2 inch fibre washer into the valve.
Having tightened the coupler as much as possible there is a very small leak. I'm assuming the olive joint is OK but to be honest I'm unsure how to tell which joint the leak is coming from.
I'm wondering if I should be screwing the coupler in until it sits on the brass shower valve (i.e. it can't tighten any further).
Would anyone have any suggestions as to what I might be doing wrong or solutions for me to try (other than getting a plumber in :D).
Thanks,
Mark
Use loctite or more wraps of PTFE. Plumbing isn’t about tightening everything up until it’s straining at the seams. It’s about having the experience to know when something is tight enough from feel
Loctite 577
The coupling is touching the backplate, more ptfe required to seal the joint before this can happen.
I like to use gas PTFE tape- yellow rolls. It's thicker than standard PTFE tape.
Seems to seal better for me on things like radiator tails.
Make the tape 'cone' shaped so the first thread has little or no tape and it gets progressively tighter as you screw the fitting in.
Thanks for all the advice.
It does make sense that when using PTFE if I can tighten the coupler down to the valve without much resistance then I need to use more PTFE.
Looking into sealants like Tru Blu, Loctite 577 or 55 and considering these pipes are being boxed in I think I'm going to go for 577 to give my novice pipework the best chance of remaining leak free.
It's a common problem with people DIY plumbing with PTFE. It seems like you are putting too much on when in reality it's actually not enough. I would start with around 15 or 16 wraps of PTFE tape and see how it tightens in. If I'm not happy with the feel of it as it tightens in I'll try it with another 4 - 5 wraps. Usually good by that point.
Before applying PTFE to threaded joints I connect the joint counting how many revolutions until it comes to the end. Helpful if aligning taps, etc.
Apply PTFE and if there is enough on, the joint will lock up before maximum revolutions reached. On deep-cut threads, it may be be wise to try on fitting part way to seat tape into threads, then undue for a further wrap or two.
As previously said, experience can tell you when its right.
Valid point made about having pipe straight into olived joint. Finger tight first, to check if straight, and then apply elbow grease via spanner.
Sorry Andy.
Great minds think alike.
I obviously didn’t read the last sentence of your above post and posted the identical thing.
Only you worded it better with the “cone” description. :)
Before you put any tape or string on the fitting roughen the thread with a file or hacksaw blade. The tape will then stay put when you wind the fitting in.
I do this on ALL threaded seals, it makes a big difference. Loctite 55 for me.
You'll find most pipe fitting thread forms come in both parallel and tapered variants.
With a tapered thread form it is the thread itself which forms the seal as the male and female sections tighten together. To prevent spiral leaks a small amount of thread tape is used to fill the small gaps.
On the other hand parallel thread forms are designed to seal either with a the addition of a washer or some form of sealing compound which cures anaerobically.
As far as I'm aware domestic plumbing fitting used in the UK are BSP parallel so you're always going to have problems sealing with PTFE etc.
You may get away with it on very low pressure applications such as radiators but even then weeps and seeps are quite common with time.
Usually only weep through time if joints were done wrong though, - often due to not enough ptfe tape.
Parallel threads aren't designed to seal with tread tape. You need a gasket of anaerobic thread sealant of some sort. If you ever have the misfortune to do a pipe fitting course they will bore you to death with this. Have a look at the literature on pipe or tube fittings, chucking a ton of PTFE tape on is not the correct way to seal a parallel thread.
Parallel Threads vs Tapered Threads | Swagelok
On parallel threads we can still easily seal them with ptfe tape.
I see no reason to use anything else on rad tails or most other male threads.
Rads, oil boilers, copper and stainless steel cylinders, some shower valves, all are parallel threads and normally perfect seal.
Agreed, as I said you may get away with it, may leak when you fit it, it may leak in 6 months time. Why not use the right product/method from the get go?
On most parallel threads (rad valve tails for example) I wouldn’t personally use anything other than ptfe tape and some paste. Been using that method since the 70s and never leaks if tail feels tight to turn. And I mean no weeps even after decades.
I was one of the first plumbers to embrace ptfe tape as an alternative to Hemp due to a friend of mine who worked in chemical development industry highly recommending it.
On fittings or valves with only 2 or 3 threads however, I would be concerned to use tape unless there is a shoulder joins to seal the metal to metal against.
So what is the proper seal for parallel threads (in the threads)?
Cord seal?
[QUOTE="Best, post: 1041804, member: 2832]
Cord seal?[/QUOTE]
PTFE is great stuff, its only really meant for tapered threads though.
Like you say you'll often get away with it on heating systems but that's largely down to them running at such low pressures.
As others have suggested Loctite 577 is a good product but I don't think its "food safe" so shouldn't be used with potable water systems.
I think Loctite 565 and 567 are suitable for use with potable water systems but you'd have to check.
Using the right stuff is only marginally more expensive and ensures no call backs.
Cord seal?
Using the right stuff is only marginally more expensive and ensures no call backs.[/QUOTE]
The cord seal I have never used, although I do have some of it.
I suppose it is having the confidence in it, plus I would be quicker with using ptfe tape.
I also use tape on oil fittings, including 1” connections to oil tanks.
Amazing stuff ptfe (in any form, - tape, liquid or hard type ptfe). I remember researching that it was invented around WW2 period.
I hate hemp (flax as I call it) due to the joints setting solid, and it being more difficult to put on threads properly
Of all the products available for sealing threads, I still use PTFE tape on just about all threaded joints.
It all about knowing how much to uses.
As the OP stated, used 10 turns and the fitting screwed all the way up.
Anyone who has been doing plumbing for anytime would realize straight away that there is a problem.
I would go as far as saying, I wouldn't have got as far as testing the joint if the finished product looked like that in the photo.
Reply to Suggestions on how I should correctly seal this value in the Plumbing Jobs | The Job-board area at PlumbersForums.net
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which...
I am seeking some advice on how to seal up my sump pit. I currently get condensation on the walls and floor around the pit, and in the past there...
I have a SIP space heater and fitted a new matching spec oil nozzle as part of a service on it. I wanted to check the pump pressure with the new...
