Discuss Superfire with primus gas. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
midlands based
Anyone use a rothenberger gun with primus gas. Im thinking of getting an adaptor as ive got loads of primus bottles knocking about so just wondered if performance was the same.
I have no problems with it. Specially if you have bottles. Be daft not to
Much increased performance as a spare hammer
ha ha,i use primus on a sf2 simply because i keep the head and 3 bottles in a old .50 calibre box,disconnect a primus bottle they dont leak,disconnect a mapp or roth bottle thy leak constantly
I use both. Got a surefire 2 with primus bottle using the adapter and a Sievert with primus bottle. Personally prefer the Sievert but surefire is sound too.
I have the Sievert with a primus bottle. When I first fire it up it is great but by the time I move it across to the fitting it is like a glorified lighter! It still does the fittings ok and have never had a leak with it yet but it is infuriatingly slow at times. I have had it stripped down several times but it makes no difference. The only time it has worked as it should was when I took it back to where I got it from. The guy there switched it on and then was able to move it around for a couple of minutes all the while with a full power flame. I took it back and the first time I tried to use it on a job it just went back to the low flame.
I would sling it but at the price of replacing it and the fact that it still works means that I will just hang on to it.
I had the sure fire one previously but after a couple of days I accidentally bumped against it and it broke in two!
I have been using my primus bottles with my sf2 for years cheapest and best.
I use sf2 but going to invest in one of the brass fine tip manual jobs that somebody on here recommended for my spare primus bottles
Reply to Superfire with primus gas. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
