Discuss terminal question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the_d_o_t
hi guys,
got a flavel firenza fire in a brick chimney with no flue liner failing on spillage and I've noticed that the terminal is the type you would use with a liner should this not be a pot?
thanks nick
It sounds like the flue needs lining to me.
Probably to much heat loss into brickwork.
If the terminal is the right size, it would be fine.
Thanks.
I think you might be right.... cant access the 4 story roof with my ladders either to inspect terminal for blockages
Reply to terminal question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
