Discuss Toilet flush pressure question in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello, I have a question on flush pressure.
When I press the bigger button, there's hardly a flush. I understand that's normal but it's a very minimal flush. And then the smaller button is quite hard to press and I think doesn't do a full flush either. So when I flush I press both and it works ok. But I'd like to fix this because I have guests coming.
Can anyone advise on how to sort it out/replace/adjust?
I think the little button is already touching the release/ it's flush against it, excuse the pun.
If you press the big white disc ontop with the screw in once eg imagine it’s the button does it flush proper or small amount ?
Eg does the cistern empty
Thanks for your reply. I took a video but cannot share a link here, it's says it's spam. Most of the water goes down with a single push, all of it with a hold.
I think the issue is that it's stiff to push the smaller button
Reply to Toilet flush pressure question in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of...
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
Hi, my Geberit duel push button has stopped flushing the toilet. When either button is pressed a small amount of water is released but not enough...
