Discuss Trappex Centramag 2 28mm - where to buy? in the Central Heating Forum area at PlumbersForums.net
After recommendations on here, I'm after replacing an old red label Magnaclean (with broken valves) for a Trappex Centramag 2. I need a 28mm but I can't find anyone who stocks them...do they exist in 28mm and where can I get one? I'd rather order online as none of my local merchants have even heard of them - I've tried emailing Trappex a few times but their customer service doesn't seem bothered to even reply!
Special order best to contact manufacturer and ask is there any one local eg approved stockist that can order it in for you
I have had the same problem this week , nobody answers the phone , the only merchants that stock them are the independents . Online may be the way . A guy called Paul Scholes is pretty quick on the emails .
I installed a centramag yesterday, my first one , and one of the valves leaked , not happy , it was a good job the customer was at work .
Paul is sending me one out but I have to go back and fit it for free as per !!!
Personally I wont fit another centramag but will try the new Genesis next .
Sorry no idea if they do a 28 mm but email Paul, and I am sure he will help.
Hmm, the leaky valves don't sound good...might just get the Magnaclean 2xp instead - the revised design will be a benefit over my old one and it should save me some pipework. Just galling that the 28mm model is £150 for a plastic tube and few valves!
Hmm indeed , I was seething to be honest , but the Genesis does look in a different league.
Fernox Omega is made in 28mm fitted one this week and have fitted several other comes with or without valves and all brass . Kop
Thanks, KOP, just taken a look - they look quite robust, will research further. Unless I'm mistaken, looks like it needs an aerosol type inhibitor, rather than just pouring into the Magnaclean? Also, why would you want one without valves? Surely always better to valve off something like this?
unless they leak down the road
Why's that ? all you do is place a container under the mag filter remove the magnet open the drain point the system pressure blasts out the debris 2 - 3 seconds job done , replace the magnet top up the system , chemicals can be added a number of ways I have a pump to get it in , you can add via a radiator or towel rail if you know how ,or use the canned stuff . Kop
I don't have any towel rails, just normal rads so I like the ease of dosing via the Magnaclean!
Piece of cake isolate your rad drain some water out through one of the rad valves into a container add the chemical as below it not like your doing it every few months , don't get me wrong the Magna clean is a quality product and has its place I use them if the install suits . Kop
[automerge]1573157423[/automerge]
Very good point! That's the only reason I'm changing my old Magnaclean - stuck valves!
Replacement valves are available ???
[automerge]1573157832[/automerge]
Non metallic as well ? Mr kopsta
Have a look here mate
Thanks, all good pro advice. I understand replacement valves are available, but the top seal is a bit dodgy as well so thought I might just replace it for the newer model. Great tip on the inhibitor through the rad so thanks for that as well.
This lack of service is not what this company will want to hear.
I have copied this to Shaz ...he will be dismayed. centralheatking
Unfortunately our computers have been down at the office.We don't manufacture a 28mm Centramag 2 but we do make an original Centramag 28mm version .Please contact us on [email protected],if you require any further information .
ok Bsp ..can you send all your current sales info to me please
Shaz has my email...Rob Foster [email protected]
[automerge]1573376613[/automerge]
I had a chat with Trappex yesterday on your behalf. Shaz apologises they have been moving offices and that was why they were behind with enquries. centralheatking
Reply to Trappex Centramag 2 28mm - where to buy? in the Central Heating Forum area at PlumbersForums.net
quality product wanted, my 1/4 turn kitchen sink tap inserts need replacing and i am looking for ones with a spindle gland nut, rather than a...
Pete Williams
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
5K
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
Hi All, We have a older Version Worcester Bosch 35CDi Boiler (probably for about 15+ years). We have never had any protection on it & Bosch...
5K
