Discuss Tumble dryer drain hose to hose connector in the USA area at PlumbersForums.net
Hello. So have bought a beko dryer which seems ok. The water collector fills up quick, good sign i think. This model comes with a drain option. The hose they have supplied looks a bit thin (pic attached). I want to plumb this into my existing
twin hose connector (pic attched). The hose opening of the hose that they have supplied seems a bit too thin to try and fit over the hose connector, although before trying it i thought id seek advice. Any suggestions please? Many thanks
Rest assured, this is a global issue.
Would you not think with the emergence of these condensating dryers over the last decade or so, some plumbing manufacturer may have come up with an easy-fit solution.
It's the 'bane of my existence' to fit these dryers to a fitting supplied by a trap manufacturer.
So how do u do it? Many thanks
There is this one, but seems expensive!
(goes on that little spigot?)
Could you measure the size of the opening in that rubber fitting of yours?
There is a Miele adaptor that is intended to be fitted in place of one of the McAlpine spigots in your pic.
I've never used one myself. Instructions for the Miele tumble dryer show how it goes. A clamp round the hose (3 as shown) seems a good idea.
You can ignore the non-return valve etc.
Miele Drain adaptor 1571760
It's one of these:
I don't promise this will work, but it's the closest/ simplest adapter that I know of.
Thankyou all for the advice. Im a bit surprised at these manufacturers making it so difficult to attach this....think im gonna go for the Miele adaptor option, seems the neatest.
I agree with you, it's very unhelpful of the manufacturers not to supply the necessary for the UK market.
I did discover that the Bosch/ Siemens/ Neff etc group do supply an adapter with their hose kit that does the same job as the Miele one:
But you don't seem to be able to just buy the adapter (the little funnel looking bit) on its own.
(this kit might be an option if the Miele adapter doesn't work for you, and you have to send it back!🙁)
Best of luck!
Reply to Tumble dryer drain hose to hose connector in the USA area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hello, I have a dishwasher that was relocated. The corrugated drain hose is in good shape but the end that would connect to the air gap was...
1K
Hi All Attempted to fit a double waste outlet today (w/machine and dishwasher) but failed. I purchase this from screwfix presuming i could i...
4K
I have an old Glow Worm Fuelsaver 40B Mk 2 installed on the kitchen wall. In November, the heat exchanger began making a kettling noise. It’s...
2K
Hi everyone, new to the forum as desperately seeking advice on the sink that has been the bane of my life for several months now! We live on a...
1K
