Discuss Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just to chuck another spanner in the works , I did my ACS last week and couldn't believe what the assessor was saying ... this is new ish , I didnt know.
Only for certain AR’s , if whatever you are AR-ing doesn't actually remove the risk , you can leave the appliance on !!!! Its in the new niceic books .
Just to chuck another spanner in the works , I did my ACS last week and couldn't believe what the assessor was saying . this is new ish , I didnt know.
But you still have to leave a notice and it is still AR?
Sorry I was wrong for once
If that’s the case mate. It definitely doesn’t happen often. :p You are one of the first people I would come to for advice as I know that you have a wealth of experience and knowledge (a heck of a lot more than me) the reason I was pushing so much was it is what I had drummed into me for years when I was on the cards. I panicked for a second that I had been doing it wrong all this time. But the rules are constantly changing so we are all wrong at some point.
I don't quite understand... Surely everything your at risking...by isolating the appliance it's going to remove the risk or am I being thick?
No your not , I thought exactly the same thing when I heard it , as we went through the re-assessment they would ask AR , turn off ? leave on ? . No joke this
Eg ( copied out off book ) no AECV at point of entry into a building where one is required, that is AR but its AR “leave on”
It’s called ‘AR no action’ and the best example I can give you is a built over PE service. Dropping the handle will not in any way reduce the risk as it’s upstream of the ECV, however the situation is still AR
AR No Action has been around for a little while.
Reply to Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
i am a landlord and have had great advice here. I am using a new gas engineer/plumber who tells me Water Quality testing is now a compulsory part...
Hi guys, These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible...
