Discuss Unsafe situation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Ryanm9783
How would I classify a Vailliant Eco tech pro boiler with a cable entering boiler but has the grommet missing , all my readings with fga are bang on and I'm fully gas safe registered please help , I would have said ncs as is a room sealed boiler/fan flued need to know asap
ryan
Is it supposed to be there-yes
is it there-no
in the event of a serious structural failure ie the seal on the burner door failing, could products of combustion freely enter the occupied area-yes
If left in its current state does it pose an immediate threat to person or property-no
If left is it AT RISK of causing a threat to person or property-yes
and that is all we will give you until you can prove you are gas safe registered. how you can do that is in the forum rules.
Well the outer cases on those arent mechanically sealed so at risk no way imho
Room sealed appliance with incomplete seals GIUSP 8.2 ID if it's positive pressure
If you're ever uncertain and it's urgent, you could always carry out a quick call to Gas Safe as that's what they're there for?
Format 100c. Whoever fitted the overheat stat had cut half the grommet away. Sime technical says ID it.
Reply to Unsafe situation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
