Discuss Unvented cylinder in loft - terminating tundish in the USA area at PlumbersForums.net
gmartine
What would folks usually opt for easiest route to soil stack?
Tesla tundish and push fit pipe and go the easiest way
That's gonna be ugly busting out of a soffit as well as putting a fall on the pipe right across the boarded out loft, any other way?
Not sure what else to add. It's an unvented cylinder install in the loft of a two bathroom extended semi-detached. I've only ever put them in cylinder cupboards, garages and utility rooms.
32mm pipe gives you plenty of options with regard to distance and bends. If not you are looking at doing it in copper tube for a neater look.
Ill need to check with client for load bearing walls to reposition it, a shorter run in copper does seem a better and neater option.
[automerge]1581964112[/automerge]
I've just found a figure for the fall required (1:200), is that right?
Only other way is to pump it but best part of 500 smacks
cant you get into a drain somewhere? down into the airing cupboard and into the bathroom or any soil vents in the loft ?
Yes, the fall on the D2 must be a minimum 1:200
If you have access to the stack then why not? That's a good solution. Alternatively you can take the D2 outside and down to the ground (must terminate within 100mm of ground level) and put a little protective cage around the end of the pipe as per regs. Obviously depending on where this is on the building it can look ugly but at the side or around the back I have found most customers don't mind the pipe showing. This also allows you to fully comply with the "Discharge visible at two points" part of the regs.
Reply to Unvented cylinder in loft - terminating tundish in the USA area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
