Discuss unvented megaflo leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TheDrip
I visited a customer yesterday afternoon as her megaflo leaking, slow dripping water from the base onto the base support. After checking usual spots I noticed water under the red plastic cover on the outlet, prised a section of to get a better look and found a nice "pond" around the hot outlet pipe. The water appears to be coming from the base of the connection, the compression nut and thread are dry, and running down between the outer cover and insulation. Built pressure back up and water reappeared. I tried to contact Megaflo help line but they only work mon - fri. Has anyone any help to solve this problem? The system, I discovered, was fitted by ex husbands brother, a non-competent person so the warranty will be null and void.
Do you mean it's leaking from the compression connection or from where the pipe is welded to the cylinder ?
It appears to be where the pipe is welded to the cylinder. The compression nut on the outlet pipe is tight and does not appear to be leaking. Is there another connection between the outlet compression nut on the pipe and the actual cylinder. Difficult to see through the insulation.
Ouch ! - Sounds like new cylinder time then. If ex husbands brother wasn't qualified, and it hasn't been serviced each year then they've got no chance of getting it replaced under guarantee.
Thanks BLOD. You have confirmed my suspicions new cylinder required. I will double check by removing insulation from around outlet pipe. No harm as its out of warranty. Thanks again.
New cylinder time, and while you are there replacing it you can take great plesure in rubbing in the fact that there cheapness at "getting a mate" in to do it has cost them the price of TWO Megaflo cylinders
do you know what mk megaflo this is because if mk 6 or newer has 25 yr warrenty
would it not be void as a diy fit?
DIY fit then no warranty, Unless the ex brother-in-law was a ticket holding plumber with enough nonce to log it with BC and fill the warranty card in. I find this thought quite ammusing :)
Reply to unvented megaflo leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, I hope someone can help me. This morning we noticed water leaking under the hot water cylinder in hotpress room. On closer inspection...
2K
Hi, We recently had the pressure tank replaced in our system as the old one started leaking. Since the replacement, I've seen two problems. The...
Problem: No hot water from unvented cylinder, although central heating works fine. Hi All - apologies for the lengthy post but I'm keen to get...
7K
K
  • Locked
Hi all, Ready for War and Peace ? Hope you are all sitting comfortably, so let me begin...p.s. I am not a plumber, I work in IT so sorry if...
16K
  • Locked
i hope someone can give me an advise on the issue that I'm currently facing, my property is a new build and its just 3 years old, the house came...
1K
