Discuss Vokera Maxin 28e Diverter valve Leak? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
aidanquigley
Hi, I think this might be a diverter valve leak? it drips at about 10 drips per minute and seems to intensify when the taps in the house are turned on. I tried screwing the bolt in but it didn't work. the hole that the bolt goes into seems to be corroded/green coloured? does anyone have any suggestions how to fix it?
Yes, get a qualified gas engineer to have a look and stop messing about inside your boiler
Reply to Vokera Maxin 28e Diverter valve Leak? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter put an isolation valve on the pipe work for this :-(, the copper pipe comes up from a plastic pipe push fit. See photo. I did a tissue paper test and...
1K
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe (3 soldered joints only) running into house to the kitchen, to gas hob (with another isolator just prior to hob). System Failing tightness test...
2K
Hi folks, I hope someone can help me. This morning we noticed water leaking under the hot water cylinder in hotpress room. On closer inspection, the water was just gushing on to the floor and it was only by chance we noticed it. We turned off the heating system and spent the morning emptying...
2K
