Discuss Vokera Maxin 28e Diverter valve Leak? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
aidanquigley
Hi, I think this might be a diverter valve leak? it drips at about 10 drips per minute and seems to intensify when the taps in the house are turned on. I tried screwing the bolt in but it didn't work. the hole that the bolt goes into seems to be corroded/green coloured? does anyone have any suggestions how to fix it?
Yes, get a qualified gas engineer to have a look and stop messing about inside your boiler
Reply to Vokera Maxin 28e Diverter valve Leak? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe...
2K
Hi folks, I hope someone can help me. This morning we noticed water leaking under the hot water cylinder in hotpress room. On closer inspection...
2K
