Discuss W/Machine waste very slow draining in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. howy1
    howy1 Member
    Hi all , I am in new build house , the wash machine is in small utility room .
    The machine is struggling to pump waste water away , all I can see is a small amount of pipe disappearing into wall / boxing , so my question is do you recommend putting a drain cleaning fluid down pipe if so do you have any recommendations please .
    Howy
  2. rpm
    rpm Trusted Plumber Top Contributor!!
    How old is the machine?
  3. Last Plumber
    Last Plumber Plumber GSR
    Have you cleaned the Washing Machine filter out? or at least checked it is clean.
  4. howy1
    howy1 Member
    Hi , I have checked the filter its a beco machine and the filter is hardly a filter its the smallest one I have seen on a machine ! also for the previous poster the machine is 2.5 years old , do you guys think the drain is ok and it could be w/m pump ! cheers howy
  5. rpm
    Not certain either way yet, I asked about age of machine as you said it was a new build. Is there a sink in the utility room, could the discharge pipe join that underneath and if so does the sink drain ok?
  6. howy1
    howy1 Member
    Sorry the implication was NEW build but 2.5 years old , no there isn't a sink in utility looking at the situation I think it might go into the stack from bathroom upstairs all enclosed as they are .
  7. Last Plumber
    It's hard to say without seeing it. If it goes into the stack it should be via a deep seal trap. The waste pipe termination would be better accessible so I would probably start with getting a look at that and take it from there.
    • Like Like x 1
  8. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    Needs more investigation I had one where the pipe was nearly solid with washing powder and a smiley mess had to be cut out and replaced , removing the washing machine stand pipe trap and cleaning it is the place to start . Kop
    • Like Like x 1
Loading...
Similar Threads - Machine waste very Forum Date
Waste hose problem for washing machine Plumbing Forum Sep 28, 2018
Sink/washing machine waste Plumbing Forum Sep 17, 2018
