Discuss Wall hung Grohe wc frame in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I maybe entiarly wrong but i dont think you can, but i stand to be corrected all the ones i have done previously have either been side or straight down exited though
I know the pan conn is removable.
And u use a standard pan con? does the bracket on the frame fit around one to hold it in place
So when the 90 pan connector is removed you could replace it with a cutting of 4' waste and put a straight pan connector on? thanks guys!
Reply to Wall hung Grohe wc frame in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone. Simple question really-Are wall hung toilet frames universal? client has one existing. So can we just replace the pan, potentially...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
Hello all, We have a small bathroom, which currently has the toilet on the outside wall, and the sink on the inside wall. What are the...
2K
Hi, just installing a wall hung toilet on a grohe duofix frame + hardie + metro tiles. All fine so far, just pushed the pan on rods and...
3K
Hi, i have recently had to do a DIY job on a wall hung toilet as couldn't get a plumber booked. I did the grohe rapid sl frame against a solid...
4K
