Discuss Wastes through joists in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nat
Hi all,
Thought I'd ask this in the Arms cuz if you follow building regs to the letter I don't think you can do this but...
Can you run an inch and a half waste through normal floor joists with a fall for a shower tray? It's probably only a couple of metres from the proposed shower trap to the stack and the tray needs to be as low as possible for accessibilty hence the need to run it through the floor.
Looking at the official guidelines for notching and drilling joists it says you can only drill in the centre of the joist so you wouldn't get a fall. I have done this before but on those new type engineered joists with the large web in the middle and that hasn't been a problem but this isn't new build and they (although I haven't taken the floor up to look) are bound to be the solid timber ones. I haven't been able to measure the depth of them either.
Has anyone done this before?
Cheers
Nat
I've not done it but I've been involved with the remedial works after a DIYer did it. We had to take the ceiling down, prop the ceiling with acrows and bolt steel plates either side of the joists to reinforce them. Total cost was over a grand without the structural engineers costs.
IMHO it's not worth the risk.
Only in certain circumstances, where the joists are really deep (e.g. large Victorian house). Even then, you have to strengthen the joists.
I'd never do this without consulting expert help (e.g. a decent construction engineer).
I've only done this the once (on said advice). All other times I've simply told the customer that it's not possible but with built a platform you overcome this.
Thanks for your response guys.
According to the guidelines though you *can* drill a 40mm hole through a 9 inch joist it's just getting the fall thats the problem.
Really didn't want to go down the platform route. F#*k!
Can you go out an adjacent wall and run external, or drop below by the wall and box in below?
I'd be going this route than messing with building structure.
You can only drill a holes on the centre axis from .25 to .4 of the span of the joist up to a maximum of 1/4 of the depth. In a 9" joist this is around 57mm so a fall is achievable. This is only if there are no other notches in the area.
The job I attended the holes were bored through the centre of the joists about half way across.
The bathroom is inbetween two bedrooms and the stack is actually internal in the bathroom. Running outside would be a very long route and it would have to drop a lot by the time it got back to the stack. Don't really think this is an option. Dropping by a wall below might be worth looking at though, thanks Simon.
Thanks for clarifying Mike. As I remember there was a solid wall below that the joists could be resting on so it's possible that the area i need to cut holes in would fall within 0.25 and 0.4 of the span.
I am obviously not a structural engineer but it's funny how you are OK to go within 0.25 and 0.4 but not as far as 0.5! The tolerances are quite exact.
You need to clear your back with this one, imho.
If you get a structural chappie in you can then pass all the blame on to him (wording this as necessary on your invoice/receipt).
It will save you the worries in the future.
one other problem if you drill tight holes will be noise from expansion. I would advise against it unless it just through one or two joist's at the 25 to 40% drill zone.
how about a pump?
is it combined wastewater and sewerage? if so it doesn't necessarily need to join the stack it could run between the joists and join a downpipe for rainwater. worth checking out.....
Got to be careful with this - not all rain water pipes go to a combined drain (and on modern houses none do) - if it's surface water only, it's against regs.
i don't know what the property is which is why i said to check it out and not just blindly do it...
Wasn't suggesting for a moment that you were advising that.
Just didn't want someone who doesn't know the building regs and might read this in the future to think that any connection to a RWP was ok.
Just realised that this thread is in the arms - so this type of thing probably isn't an issue - apologies.
Matt
Interesting thought.
How do you check this out?
lift the manhole covers, run the sink, flush the bog, put hose pipe down guttering and see where they all come out.
I know there is a website that will give an idea of what drains the property is likely to have based on the age of property and area etc. it is not a definitive answer but gives a guide, I can't remember what it's called, possibly this will prompt someone else to provide the name.
Reply to Wastes through joists in the Plumbing Jobs | The Job-board area at PlumbersForums.net
