Discuss Water Regs/ Unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dazb
Recently I completed the complex cold water and domestic hot water units for the C&G 6035 Level 3 Diploma in Plumbing and was was told I wouldn't have to do the Water Regs and Unvented certificates because these tests covered them. This confused me because because I don't know what I would need to do in relation to certification, etc...
Not sure but will find out whether 6035 is fully aligned, if it is then you just need to show our C&G certs that cover these two areas.
Seems daft to me (with all due respect) this is just a college based qualification so you are likely to not have had any piratical experience in these two important areas of of our work & yet would be deemed competent !!!
you are likely to not have had any piratical experience in these two important areas of of our work !!!
Is that the bit where we pull out our cutlasses and demand our gold doubloons, threatening to make them walk the plank if they don't pay up? :p
Reply to Water Regs/ Unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Full disclosure, I am an Electrician. One of my older clients has just had her fire capped off because it doesn't comply with today's regs and...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
I got my water regs when I completed my NVQ level 3, in 2017. Do you have to renew this every year?
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version...
