Discuss what inserts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
what brand of isolation valves do you use with plastic pipe system?
Yes, insert it right in until the "lip" reaches the end of the pipe. This will add an extra 2.5mm to the amount of slip into a compression fitting, so it's vital that you use quality compression fittings such as Kuterlite that has a deep slip and use soft copper olives not brass.so what your saying is that the whole insert, has be inside the the fitting? thanks
When I use Speedfit, I can either use a Kuterlite (expensive) or a straight with a cutting of copper, then the cheapo iso valve compressed to that or better still I buy these by the bucket load and they have never let me down:what brand of isolation valves do you use with plastic pipe system?
Plumbing Supplies Wholesale - JG SPEEDFIT SERVICE VALVE
My no.1 preference is still copper with soldered fittings, followed by compression, then Cuprofit pushfit.
Reply to what inserts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
