Discuss What reducer do I need? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
And a 35 mm coupling/ adapter if it's imperial
Just out of curiosity. What are you connecting?
Am fitting a Fernox TR1 into the return line, 35mm, to the boiler. The TR1 is the 28MM version. On boiler replacement, next year, will correct directly into the boiler 28mm pipework but for now want to fit it to current boiler line.
I would use a spyro 35mm from city plumbing. Put the 28mm in when you fit the boiler.
Not sure why I need a 35mm to 35mm or 35mm to 1 and qrtr
Because the reducer you have is a fitting reducer so it's the same dia as the 35mm pipe so you need a coupling
TBH it sounds like you might need the help of a heating engy
Yep that will do also
Reply to What reducer do I need? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
