Discuss Which flush mechanism will fit my toilet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sincers
Hi, can anyone advise me please if a standard new type of flush mechanism will fit this toilet?
James
Try this and also get a new donut for the pan/cistern coupling if it is a close coupled toilet.
Fluidmaster Button Cable Dual-Flush & Bottom Inlet (58353) (Screwfix) & WC Close Coupling Kit (84958) (Screwfix).
If your loo is an ideal standard one you will be better buying the idea standard close coupling kit as more sturdy.
Simple to fit just don't forget to turn water off.
If no local isolation valve then fit one when the water if off. Then you can work at your own pace.
And welcome to the forums.
These jobs can take longer than expected and a cuppa helps! lol
Also, is it possible to fit the flush valve without changing the bottom inlet?
James
James
Yes you can fit just the flush valve/syphon if you choose. You will still have to undo the connection to the inlet valve so you can lift the cistern off to work on it but you can leave the inlet in place and reconnect to it when you are done. I'd replace the 1/2" red fibre washer in the connector to the inlet whilst you're at it as they often don't reseal when used a second time.
Update re:Which flush mechanism will fit my toilet?
I installed the fluid master today and it was surprisingly straight forward and seems to work a lot more efficiently than the old mechanism. Thanks Stigster for the tip on changing the fibre washer on the supply pipe as it was in bits. Thanks everyone for the advice, The Mrs is well happy she can flush the bog now without getting her fingers wet! Haha
Cheers
James
Thanks for the update James, much appreciated as too few people bother to take the time.
Reply to Which flush mechanism will fit my toilet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
