Discuss Why is the Trv leaking after removing radiator in the USA area at PlumbersForums.net
I've isolated the trv end and lockshieds end to remove a radiator, however the the trv is still aklowong drips of water to cone through. How do I stop it completely?
It's coming from the main inlet pipe face
Thank you
1/2 blanking cap end should sort you out
Some trv s don’t totally could be either the head isn’t on correctly/ fully tighten
Fair point. Is it best to take the trv head off and unscrew fully to an open position from * to 7 and then replace back onto the needle head at position 7bwhich is fully open?
yes and tighten the collar down then switch / turn the trv off but don’t do it now else you will flood yourself :D
Just bought 1/2 inch blanking nut but is too small, I think it should be 3/4 to screw directly onto the threaded trv open end, is that correct?
trv will be 1/2 lockshield will be 3/4
1/2 should measure around 20mm od
Hi the threaded trv outside dia is 25mm. Is there a blanking nut for this thread so I can cap of the trv Insitu. So in effect like tightening up with the union nut on the radiator
you are correct its 3/4 never seen a trv in domestic with a 3/4 nut
A 3/4 blanking cap should fit that thread but I cannot absolutely guarantee that. Like Shaun says, I too have never seen a 3/4" TRV outlet in a house before but there it is, looks like that's what you've got.
Yes these are from 1996, valliant.
This is the current modification I have made follwing the purchase of the 1/2 inch blanking nut,
I wouldn’t just dose with x100
Just add x100 when your finished
Reply to Why is the Trv leaking after removing radiator in the USA area at PlumbersForums.net
