Discuss Will a 22mm pipe cutter work on older 3/4"? in the USA area at PlumbersForums.net
Hi All
Pretty explanatory really, need to cut some old 3/4" pipe feeding H+C bath taps, access is very tight.
Will my 22mm cutter work on 3/4", if not what can i use?
My Monument Autocut ones work okay. I have the metal bodied ones that initially go on easily and seem to only bite the tube once you start to rotate them. The plastic version is nowhere near as good as it does not do this.
Reply to Will a 22mm pipe cutter work on older 3/4"? in the USA area at PlumbersForums.net
Sonya K
