Discuss Will a 22mm pipe cutter work on older 3/4"? in the USA area at PlumbersForums.net
Shouldn't be a problem if you can get access. The OD of 22mm tube is 22.00 mm. The OD of 3/4" copper pipe is normally 21.49 mm.Will my 22mm cutter work on 3/4", if not what can i use?
Reply to Will a 22mm pipe cutter work on older 3/4"? in the USA area at PlumbersForums.net
