Discuss Will plumbers mait seal a 32mm ABS pipe joint? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
robbie71
I have a leaky waste pipe from a sink,
When i looked at the pipes, 2 of the joints on an elbow were loose and came apart easily.
the pipe is black and dirty and a there seems to be a lot of play when inserted in the elbows.
i dont want to replace the pipes as there is a bend on one that I can't replicate.
is it possible to re-weld the joints in this condition?
if not , would "plumbers mait" seal the joints?
thanks
look beyond the attempted repair before you start what will you do if it dosen`t work cut it out and start again.. forget plumbers mate. If you can get the pipe and fittings apart clean
pipe and fittings with pipe cleaner before solvent welding with solvent pipe cement good luck:)regards turnpin
gonk of silicone for a bodge left overnight will work rough but works
Reply to Will plumbers mait seal a 32mm ABS pipe joint? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm...
Morning All, Just after some advice as I have been asked to plumb in a sink and washing machine waste for a new kitchenette. The other side of the...
2K
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new...
2K
I have this at home: Glue and I need to solvent-weld these abs drain piping: pipe and elbow Can I avoid purchasing solvent cement? Or would that...
