Discuss Wirelse's stat working opposite way round ?HELP PLEASE . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I have a ideal vogue 32kw combi.
It was wired direct to a fuse spur and I am trying to fit a salus wirless stat and programmer.
I have fitted the receiver as per instructions and removed the link on the boiler but the stat is calling for heat when it should be switches off and then not calling for heat when it should be.
I have swapped the com and no wires over and it's still exactly the same....
Can anyone shed some light in this ??
Thanks in advance
Chris
You shouldn't be removing the cover from a gas appliance unless qualified to do so. Please read forum rules.
Reply to Wirelse's stat working opposite way round ?HELP PLEASE . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
