Discuss wiring condensate pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jimboze
hello im trying to figure out how to wire a condensate pump to the boiler. the pump comes with a standard live, neutral and earth and two wires that cut the boiler supply if pump overflows/blocks.
now as i understand it i connect one of the 2 black wires to the permanent live terminal on the boiler then connect the the other wire to the original permanant live cable via a terminal block.
now im not sure which is the permanent live cable on the boiler. there are two wires from the thermostat control brown and blue. a couple of pink ones and a couple of yellow cables on the terminal block.
sorry about the repeated uploads.
Hi Jim
Welcome to the forum, if you dont understand basic wiring I think its wise to get a qualified electrician in
Hi Jim
+1. This one won't take an electrician long. And with it invoking water and a poss leak. May be worth it for the mind
Reply to wiring condensate pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
