Discuss Worcester 37cdi combo E9 fault code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester 37cdi combi & over the last couple of weeks it has been cutting out with the E9 fault code showing.
This evening I have reset it numerous times.
Any suggestions what is causing this ?
What's the pressure at ? Should be a dial on the front of the boiler
Is that with the heating warm or cold ?
I would say up the pressure upto 1.8-1.9 bar
I have upped the pressure but as soon as i turn the hot water on it cuts out with the E9 fault code.
When I press reset the green light is lit indicating the boiler is lit but there doesn’t appear to be anything coming out of the flue although the rads are getting hotter.
Sorry to say time to get a gas safe engy out
Reply to Worcester 37cdi combo E9 fault code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
