M
MichaelwGroves
What models would you recommend, all my pipe work is 22mm, so I would look to replace 3 way with 22mm T, striaght into 2 port valves ?
Discuss Worchester Bosch E9 Error - It's not the boiler ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
That's mad, why does Worchester Bosch only come off the boiler in 22mm ?
Sorry, don't mean to be argumentative but...........
I don't see how 28mm will give better flow if boiler is only 22mm. But, I can see upgrading pipe at valve to 28mm to get full 22mm through valve.
snip from Manuel, "Even if the heating output is limited, the full rated heat output remains available for hot water"
1.a is setting for CH, 1.b is setting for Hot Water.
What are the advantages/disadvantages sealed over vented?
What's the advantages/disadvanteges sealed over vented?
I get it now, coming straight out of the boiler in 22mm will have similar resistance as going round a 90 degre bend in 28mm. I have some further upgrades planned, so will look to upgrade pipe and valves at the same time.
have you got that manual on pdf mate
I hate to admit I am wrong, but Vern I reckon you were right about the boiler as well. Obviuos when you think about that one
So do I assume the hot water setting has no effect on my boiler, or should I set this the same?
Does 1b alter the output if you had the diverter valve kit fitted do you know vern.
Gas analyser?!?
Reply to Worchester Bosch E9 Error - It's not the boiler ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
